跳转到主内容
CCM Ice Skates Steel Blade Replacement
你所需要的
  1. CCM Ice Skates Steel Blade Replacement, Steel Blade On CCM Skates: 步骤 1 中的图像 1,1
    • Place the palm of one hand over the laces at the middle of the skate boot.
    • Close that palm and firmly grasp the skate.
    • Use the other hand to grab and remove any skate guard.
  2. CCM Ice Skates Steel Blade Replacement: 步骤 2 中的图像 1,1
    • Place the heel/back portion of the skate on the table.
    • Firmly grasp the toe of the skate with one hand.
    • Insert the flat head screwdriver from a multi-tool into the groove of the first screw and hold.
  3. CCM Ice Skates Steel Blade Replacement: 步骤 3 中的图像 1,1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the first screw.
    • Turn the flat head screwdriver in a counter clockwise rotation until it is loose.
  4. CCM Ice Skates Steel Blade Replacement: 步骤 4 中的图像 1,1
    • Remove the loosened screw from the white plastic blade holder.
    • Insert the screwdriver into the fastener and apply pressure to remove the fastener.
  5. CCM Ice Skates Steel Blade Replacement: 步骤 5 中的图像 1,1
    • Insert the flat head screwdriver from a multi-tool into the groove of the second screw and hold.
  6. CCM Ice Skates Steel Blade Replacement: 步骤 6 中的图像 1,1
    • Using multi-tool pliers, grab hold of the fastener on the other side of the second screw.
  7. CCM Ice Skates Steel Blade Replacement: 步骤 7 中的图像 1,1
  8. CCM Ice Skates Steel Blade Replacement: 步骤 8 中的图像 1,1
    • Wrap a hand in a cloth towel.
    • Pinch the two flat sides of the metal blade between the thumb and index finger.
    • Do not touch the bottom or edges of the blade.
  9. CCM Ice Skates Steel Blade Replacement: 步骤 9 中的图像 1,1
    • Apply pressure to the sides of the blade with your fingers.
    • Slowly pull the blade upward.
    • To avoid injury, do not pull the blade up in one quick motion.
结论
Steven Marcyan
于10/04/17注册
101 声望
撰写一个指南
团队
Michigan Tech, Team S5-G9, Galliah Fall 2017 Michigan Tech, Team S5-G9, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S5G9
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 44
总计 5,993
