跳转到主内容
加入维修社区 - 创建账户
CASIO fx-570MS Battery Replacement
你所需要的
  1. CASIO fx-570MS Battery Replacement, charger: 步骤 1 中的图像 1,2 CASIO fx-570MS Battery Replacement, charger: 步骤 1 中的图像 2,2
    • Flip the calculator over so the bottom is facing upwards.
  2. CASIO fx-570MS Battery Replacement: 步骤 2 中的图像 1,3 CASIO fx-570MS Battery Replacement: 步骤 2 中的图像 2,3 CASIO fx-570MS Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the screw from the battery hatch on the top-right corner using a 1.5 mm slotted screwdriver.
    • Remove the battery hatch.
  3. CASIO fx-570MS Battery Replacement: 步骤 3 中的图像 1,3 CASIO fx-570MS Battery Replacement: 步骤 3 中的图像 2,3 CASIO fx-570MS Battery Replacement: 步骤 3 中的图像 3,3
    • Insert a spudger into the dent to the left of the battery until it hits the bottom of the panel board.
    • To create leverage, gently push the spudger towards the bottom of the battery (pushing your hand downwards and towards the back cover if necessary) to lift the battery out of its compartment.
    • Caution: Be careful to not rupture the battery or damage the panel board.
  4. CASIO fx-570MS Battery Replacement: 步骤 4 中的图像 1,3 CASIO fx-570MS Battery Replacement: 步骤 4 中的图像 2,3 CASIO fx-570MS Battery Replacement: 步骤 4 中的图像 3,3
    • When you insert the new battery into the battery compartment, it should remain bulged upwards on the side towards the dent.
    • Make sure the flat side of the battery is facing upwards.
    • To finish inserting the new battery into the battery compartment, gently press the bulged corner with your finger until it slides into place.
  5. CASIO fx-570MS Battery Replacement: 步骤 5 中的图像 1,2 CASIO fx-570MS Battery Replacement: 步骤 5 中的图像 2,2
    • Close the plastic hatch and secure the screw.
  6. CASIO fx-570MS Battery Replacement: 步骤 6 中的图像 1,2 CASIO fx-570MS Battery Replacement: 步骤 6 中的图像 2,2
    • Flip the calculator on its back and press the 'ON' button to power it up.
    • A zero will appear on the bottom right corner of the LED display.
结论
Your beloved CASIO fx-570MS Scientific Calculator is good to go for another few years.
3等其他人完成本指南。
Saquib Ahmed
于09/20/20注册
205 声望
撰写一个指南
团队
1指南评论
How much does the battery cost?
Tamanna - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 73
过去 30 天: 341
总计 57,001
