跳转到主内容
CASIO fx-50FH II Scientific Calculator Battery Replacement
你所需要的
  1. CASIO fx-50FH II Scientific Calculator Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • To turn the calculator off, first press the "shift" button.
    • Release the "shift" button, then press the "AC" button.
  2. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 2 中的图像 1,2 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 2 中的图像 2,2
    • Place the calculator face down, then use a Phillips #00 screwdriver to remove the single screw securing the battery hatch in the top right corner.
  3. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 3 中的图像 1,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 3 中的图像 2,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 3 中的图像 3,3
    • Push the battery hatch to the right until it slides off.
  4. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 4 中的图像 1,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 4 中的图像 2,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 4 中的图像 3,3
    • Put on a pair of protective gloves before handling the battery to eliminate the risk of chemical burns.
    • Insert the tip of a spudger into the indent on the right-hand side of the battery to lift the edge of the battery up.
    • Lift the battery up and out.
  5. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 5 中的图像 1,1
    • Inspect the battery compartment any alkaline residue.
    • If no residue is present, skip to Step 7.
  6. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 6 中的图像 1,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 6 中的图像 2,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 6 中的图像 3,3
    • Use a cotton swab dabbed with white vinegar to wipe the alkaline off the battery compartment.
    • Use a dry cotton swab to remove the vinegar and alkaline residues.
    • Let the battery compartment dry completely.
  7. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 7 中的图像 1,1
    • Insert a new LR44 1.5V alkaline button battery into the compartment, with the positive sign facing up.
  8. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 8 中的图像 1,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 8 中的图像 2,3 CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 8 中的图像 3,3
    • Reattach the battery hatch by sliding the hatch in from the right to the left.
  9. CASIO fx-50FH II Scientific Calculator Battery Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips #00 to secure the screw.
结论
You have successfully replaced the battery of  a CASIO fx-50FH II Scientific Calculator!
另外一个人完成了本指南。
Cheuk Wai Chan
于07/05/22注册
196 声望
撰写一个指南
团队
York University, Team M-4, Allen Summer 2022 York University, Team M-4, Allen Summer 2022 的会员
YORK-ALLEN-SU22SMG4
1 名成员
创作了2篇指南
2条评论
Very nice guide! I found the pictures to be very good and corresponding to the steps very well.
Frank Loi - 回复
Thank you for the steps. I followed the steps and managed to salvage my calculator which I almost had to throw away. This has helped reduce waste. :)
Nancy Yeo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 89
总计 1,858
