跳转到主内容
CASIO CDP-230R Panels Replacement
你所需要的
  1. CASIO CDP-230R Panels Replacement, Panels: 步骤 1 中的图像 1,3 CASIO CDP-230R Panels Replacement, Panels: 步骤 1 中的图像 2,3 CASIO CDP-230R Panels Replacement, Panels: 步骤 1 中的图像 3,3
    • Flip the keyboard upside down, with the keys on a flat surface.
    • Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
  2. CASIO CDP-230R Panels Replacement: 步骤 2 中的图像 1,3 CASIO CDP-230R Panels Replacement: 步骤 2 中的图像 2,3 CASIO CDP-230R Panels Replacement: 步骤 2 中的图像 3,3
    • Use two hands to grab the side panel from both sides.
    • Pull the panel apart from the device one side at a time.
    • There will be popping sounds when you remove this panel.
    • One side panel will not have an orange & white cable connected to it.
  3. CASIO CDP-230R Panels Replacement: 步骤 3 中的图像 1,3 CASIO CDP-230R Panels Replacement: 步骤 3 中的图像 2,3 CASIO CDP-230R Panels Replacement: 步骤 3 中的图像 3,3
    • Remove the three silver 10mm screws with a J1 screwdriver on the bottom half of the innermost side panel of the device.
    • One side panel will not have an orange & white cable running through.
  4. CASIO CDP-230R Panels Replacement: 步骤 4 中的图像 1,3 CASIO CDP-230R Panels Replacement: 步骤 4 中的图像 2,3 CASIO CDP-230R Panels Replacement: 步骤 4 中的图像 3,3
    • Remove the innermost side panel by pinching the top and bottom of the panel and pulling the panel off with both hands.
    • Repeat steps one through four to remove the other side panel of the keyboard.
  5. CASIO CDP-230R Panels Replacement: 步骤 5 中的图像 1,3 CASIO CDP-230R Panels Replacement: 步骤 5 中的图像 2,3 CASIO CDP-230R Panels Replacement: 步骤 5 中的图像 3,3
    • Remove the two black 30 mm J head screws with a J1 screwdriver to remove the long black bar.
    • Remove the four silver 8mm x 2mm J head screws with a J1 screwdriver and the two brackets from the back panel.
    • There will be two screws per bracket.
  6. CASIO CDP-230R Panels Replacement: 步骤 6 中的图像 1,3 CASIO CDP-230R Panels Replacement: 步骤 6 中的图像 2,3 CASIO CDP-230R Panels Replacement: 步骤 6 中的图像 3,3
    • Remove the eight silver 10mm x 1.5mm J head screws with a J1 screwdriver and the square tabs from the back panel.
    • Remove the eight silver 10mm J head screws with a J1 screwdriver underneath the square tabs.
  7. CASIO CDP-230R Panels Replacement: 步骤 7 中的图像 1,3 CASIO CDP-230R Panels Replacement: 步骤 7 中的图像 2,3 CASIO CDP-230R Panels Replacement: 步骤 7 中的图像 3,3
    • Remove the 36 silver 10mm J head screws with a J1 screwdriver from the back panel.
  8. CASIO CDP-230R Panels Replacement: 步骤 8 中的图像 1,3 CASIO CDP-230R Panels Replacement: 步骤 8 中的图像 2,3 CASIO CDP-230R Panels Replacement: 步骤 8 中的图像 3,3
    • Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
    • Having a extra pair of hands will be useful.
    • Grab the center of the front panel with two hands and lift to remove panel.
    • Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
结论
Areli Reyes
于10/01/17注册
545 声望
创作了4篇指南
团队
Cal Poly, Team S4-G2, Livingston Fall 2017 Cal Poly, Team S4-G2, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G2
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,092
