跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的CANDY CON Wireless Controller,应参考我们的维修指南
  1. CANDY CON Wireless Controller Teardown, Remove the faceplate: 步骤 1 中的图像 1,2 CANDY CON Wireless Controller Teardown, Remove the faceplate: 步骤 1 中的图像 2,2
    • Locate the indentation on the bottom of the controller
    • Pull the faceplate off using a fingernail or spudger
  2. CANDY CON Wireless Controller Teardown, Remove Joysticks and D-pad: 步骤 2 中的图像 1,2 CANDY CON Wireless Controller Teardown, Remove Joysticks and D-pad: 步骤 2 中的图像 2,2
    • Remove both joysticks and the D-pad by carefully pulling up
  3. CANDY CON Wireless Controller Teardown, Begin opening the base controller: 步骤 3 中的图像 1,3 CANDY CON Wireless Controller Teardown, Begin opening the base controller: 步骤 3 中的图像 2,3 CANDY CON Wireless Controller Teardown, Begin opening the base controller: 步骤 3 中的图像 3,3
    • Remove 8 Phillips screws with a Philips #1 screwdriver
    • Pry open the two main pieces by pulling up on the edges of the controller
  4. CANDY CON Wireless Controller Teardown, Finish opening the base controller: 步骤 4 中的图像 1,2 CANDY CON Wireless Controller Teardown, Finish opening the base controller: 步骤 4 中的图像 2,2
    • Separate the controller by flipping it on its face and then prying up near the bottom buttons
  5. CANDY CON Wireless Controller Teardown, Unplug the battery: 步骤 5 中的图像 1,1
    • Unplug the battery using a spudger tool
  6. CANDY CON Wireless Controller Teardown, Unscrew the mainboard: 步骤 6 中的图像 1,1
    • Unscrew the 2 Phillips #1 screws securing the mainboard to the controller housing
  7. CANDY CON Wireless Controller Teardown, Remove the mainboard and haptic motors: 步骤 7 中的图像 1,3 CANDY CON Wireless Controller Teardown, Remove the mainboard and haptic motors: 步骤 7 中的图像 2,3 CANDY CON Wireless Controller Teardown, Remove the mainboard and haptic motors: 步骤 7 中的图像 3,3
    • Carefully remove the mainboard and attached haptic motors by pulling it up from the bottom and then top
    • Be careful removing the haptic motors to ensure the wires do not break
  8. CANDY CON Wireless Controller Teardown, Teardown Complete!: 步骤 8 中的图像 1,2 CANDY CON Wireless Controller Teardown, Teardown Complete!: 步骤 8 中的图像 2,2
    • All buttons are keyed so they can only go in the exact spot they belong
  9. CANDY CON Wireless Controller Teardown, Reassembly tips: 步骤 9 中的图像 1,3 CANDY CON Wireless Controller Teardown, Reassembly tips: 步骤 9 中的图像 2,3 CANDY CON Wireless Controller Teardown, Reassembly tips: 步骤 9 中的图像 3,3
    • Follow the teardown guide in reverse to reassemble the controller
    • When reassembling the controller align the bottom buttons first and then work on the charging port side
    • Test all the buttons before or right after screwing in the mainboard
    • The D-pad has an arrow on the top that should point up (towards the arrow on the base controller)
Roger
于04/23/24注册
229 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 34
总计 924
