跳转到主内容
C. BLV NeoPixel Board
你所需要的
  1. C. BLV NeoPixel Board, Flashing the NeoPixel Board: 步骤 1 中的图像 1,1
    • Disconnect the TX/RX wires from the Duet.
    • After downloading and installing the CH340 Driver from the FYSTEC Github
    • Add a jumper to "UVCC to 5V". If you skip this step you will not be able to flash the board.
    • Download the sketch from Github and extract the zip file. Open it in Arduino IDE
    • Board is "Arduino Pro or Pro Mini"
    • Processor is "ATmega328P (5V, 16 MHz)"
    • Upload the sketch to the board
    • When upload is complete, remove the jumper.
  2. C. BLV NeoPixel Board, NeoPixel Rings: 步骤 2 中的图像 1,2 C. BLV NeoPixel Board, NeoPixel Rings: 步骤 2 中的图像 2,2
    • Left(Heatbed) connects to port #3 on the BLV NeoPixel board
    • Middle(Hotend) connects to port #1 on the BLV NeoPixel board
    • Right(print status) connects to port #2 on the BLV NeoPixel board
  3. C. BLV NeoPixel Board, Errors Opening Sketch: 步骤 3 中的图像 1,3 C. BLV NeoPixel Board, Errors Opening Sketch: 步骤 3 中的图像 2,3 C. BLV NeoPixel Board, Errors Opening Sketch: 步骤 3 中的图像 3,3
    • You might receive an error saying you need "NeoPixel_BLV.ino needs to be in a folder named NeoPixel_BLV". You have 2 options.
    • This will create a new folder and move the sketch into the newly created folder. Click OK than close Arudino IDE. Move the highlighted files and folder into the new folder "NeoPixel_BLV". You can now reopen the sketch and it should compile without issue.
    • You can also rename the sketch's parent folder to "NeoPixel_BLV". When you open the sketch you won't receive the error.
  4. C. BLV NeoPixel Board, Duet 3 Usage: 步骤 4 中的图像 1,2 C. BLV NeoPixel Board, Duet 3 Usage: 步骤 4 中的图像 2,2
    • Because the CH340 drives RX to ~4.5v it doesn't communicate with the Duet 3. To remedy this you need to either cut the trace or de-solder the pad on the CH340(green) or on the ATMega(red). I would suggest de-soldering the pad on the CH340 because it's easier.
    • In addition to the current wiring schematic you'll also need to to connect the TX from the Arduino to RX on the duet
    • Arduino RX > Duet 3 io1.out
    • Arduino TX > Duet 3 io1.in
    • Arduino GND > Duet 3 io1.GND
    • After the modifications you will no longer be able to upload a sketch using the USB port. You have to use a FTDI serial adapter and connect it to the 6 header pins next to the USB port.
    • For firmware versions prior to RRF 3.4.
    • If using IO_0: M575 P1 S1 B57600.
    • If using IO_1: M575 P2 S1 B57600
    • For firmware versions RRF 3.4 and later
    • If using IO_0: M575 P1 S0 B57600.
    • If using IO_1: M575 P2 S0 B57600
终点
4等其他人完成本指南。
David Husolo
于06/16/21注册
9,232 声望
创作了33篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 2,429
