简介
I will teach you step by step how to dissemble the device and replace the damaged buttons.
配件
无需配件。
  1. Unscrew the screws on the top side of the device.
    • Unscrew the screws on the top side of the device.
  2. Take the top lid off of the device.
    • Take the top lid off of the device.
  3. Unscrew the screws holding the pink button sheet.
    • Unscrew the screws holding the pink button sheet.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Remove the button sheet off of the device.
    • Remove the button sheet off of the device.
  6. Examine the button sheet to check for any damages that may prevent the buttons from working.
    • Examine the button sheet to check for any damages that may prevent the buttons from working.
  7. Examine closer at the button sheet for sticks on the opposite side of the buttons.
    • Examine closer at the button sheet for sticks on the opposite side of the buttons.
  8. If the button sheet or button is damaged, you may need to purchase a new button sheet to replace the damaged one.
    • If the button sheet or button is damaged, you may need to purchase a new button sheet to replace the damaged one.
结论
To reassemble, follow these steps in reverse order.
另外一个人完成了本指南。
Chotipong Chamchalaem
于2012年09月26日注册
80 信誉积分
创作了2篇指南
团队
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G50
5 名成员
创作了8篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 170
