当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Throughout this step, make sure you support the handle and head with at least three hands.
Slide the bearing rod out of the head.
Inspect the bearing rod and head for any wear or tear.
Firmly lift the riser main slider with two hands.
Use caution not to drop the riser main, as this can damage the pump cylinder.
Lift the slider and riser main pipe.
Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
Carefully lower the riser main and slider to allow it to rest on the rod clamp.
Remove the riser main slider, and inspect it for wear and tear.
Set the slider in a sanitary place to prevent contamination.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
