当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Test pump performance by pumping 40 strokes.
An effective pump should return at least 10 liters.
Remove the two pins connecting the handle to the slider.
Pull the two lever arms away from the slider.
Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
Throughout this step, make sure you support the handle and head with at least three hands.
Slide the bearing rod out of the head.
Inspect the bearing rod and head for any wear or tear.
Remove the head and handle, and place them on a clean surface to prevent contamination.
取消:我没有完成这个指南。
与4其他贡献者
于04/18/11注册
117,325 声望
创作了57篇指南
徽章: 51
+ 48更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 176
