跳转到主内容
Bush Pump Head and Handle Replacement
  1. Bush Pump Head and Handle Replacement, Head and Handle: 步骤 1 中的图像 1,2 Bush Pump Head and Handle Replacement, Head and Handle: 步骤 1 中的图像 2,2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Head and Handle Replacement: 步骤 2 中的图像 1,2 Bush Pump Head and Handle Replacement: 步骤 2 中的图像 2,2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Head and Handle Replacement: 步骤 3 中的图像 1,2 Bush Pump Head and Handle Replacement: 步骤 3 中的图像 2,2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Head and Handle Replacement: 步骤 4 中的图像 1,2 Bush Pump Head and Handle Replacement: 步骤 4 中的图像 2,2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Head and Handle Replacement: 步骤 5 中的图像 1,3 Bush Pump Head and Handle Replacement: 步骤 5 中的图像 2,3 Bush Pump Head and Handle Replacement: 步骤 5 中的图像 3,3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Head and Handle Replacement: 步骤 6 中的图像 1,1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
结论
Jake Devincenzi
于04/18/11注册
117,328 声望
创作了57篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 176
