本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to remove the cylinder that encases the traveling valve and foot valve.
你所需要的
Remove the above grade riser pipe.
Firmly screw a T-handle onto the pump rod.
Use a pipe wrench to loosen and remove the pump spout.
Place the spout on a clean surface to prevent any contamination.
Place one wrench on the top of one of the pump riser plate bolts.
Place another wrench around the bottom of the bolt.
Pull the wrenches apart to loosen the bolt.
即将完成!
结论
