跳转到主内容
Bush Pump Above Grade Riser Pipe Replacement
你所需要的
  1. Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: 步骤 1 中的图像 1,2 Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: 步骤 1 中的图像 2,2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Above Grade Riser Pipe Replacement: 步骤 2 中的图像 1,2 Bush Pump Above Grade Riser Pipe Replacement: 步骤 2 中的图像 2,2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Above Grade Riser Pipe Replacement: 步骤 3 中的图像 1,2 Bush Pump Above Grade Riser Pipe Replacement: 步骤 3 中的图像 2,2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Above Grade Riser Pipe Replacement: 步骤 4 中的图像 1,2 Bush Pump Above Grade Riser Pipe Replacement: 步骤 4 中的图像 2,2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Above Grade Riser Pipe Replacement: 步骤 5 中的图像 1,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 5 中的图像 2,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 5 中的图像 3,3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Above Grade Riser Pipe Replacement: 步骤 6 中的图像 1,1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: 步骤 7 中的图像 1,2 Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: 步骤 7 中的图像 2,2
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Bush Pump Above Grade Riser Pipe Replacement: 步骤 8 中的图像 1,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 8 中的图像 2,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 8 中的图像 3,3
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Bush Pump Above Grade Riser Pipe Replacement: 步骤 9 中的图像 1,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 9 中的图像 2,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 9 中的图像 3,3
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Bush Pump Above Grade Riser Pipe Replacement: 步骤 10 中的图像 1,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 10 中的图像 2,3 Bush Pump Above Grade Riser Pipe Replacement: 步骤 10 中的图像 3,3
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Bush Pump Above Grade Riser Pipe Replacement: 步骤 11 中的图像 1,2 Bush Pump Above Grade Riser Pipe Replacement: 步骤 11 中的图像 2,2
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
  12. Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: 步骤 12 中的图像 1,3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: 步骤 12 中的图像 2,3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: 步骤 12 中的图像 3,3
    • Remove the above grade riser pipe.
    • Firmly screw a T-handle onto the pump rod.
    • If you are replacing the above ground riser main, leave the T-handle attached until you are ready to install the replacement part.
结论
2等其他人完成本指南。
Jake Devincenzi
于04/18/11注册
117,301 声望
创作了57篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 422
