跳转到主内容
Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement
你所需要的
  1. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach the seat from the frame: 步骤 1 中的图像 1,1
    • Push both the white square buttons under the seat at the same time, to remove the seat from the frame.
  2. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: 步骤 2 中的图像 1,1
    • Put the frame with the handle on the ground like shown in the picture, to have better access to the swivel wheels.
  3. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Detach swivel wheel: 步骤 3 中的图像 1,1
    • Press the button above the swivel wheel, and pull out the swivel wheel
  4. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: 步骤 4 中的图像 1,3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: 步骤 4 中的图像 2,3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove screws: 步骤 4 中的图像 3,3
    • Remove the two screws on the black cylinder on the bottom with the Torx screwdriver.
    • Make sure not to lose the screws, since you need them for the reassembly later.
  5. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom part of the cylinder. You can use your screwdriver to pull it out.
  6. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: 步骤 6 中的图像 1,3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: 步骤 6 中的图像 2,3 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Remove old part: 步骤 6 中的图像 3,3
    • Push the old button, and place the flathead screwdriver behind the button
    • Push the button down and towards the opening of the cylinder.
    • Take out the wheel lock button and the spring, and make sure not to lose the spring.
  7. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: 步骤 7 中的图像 1,2 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attaching the new part: 步骤 7 中的图像 2,2
    • Pull the spring from the old part.
    • Attach it to pin on the new swivel wheel lock.
  8. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Placing the new part in the stroller: 步骤 8 中的图像 1,1
    • Put the new part with the spring back inside the cylinder, in the orientation shown in the picture.
  9. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Reassembling: 步骤 9 中的图像 1,1
    • Place the inner black cylinder back into the outer cylinder.
  10. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: 步骤 10 中的图像 1,2 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Securing the part: 步骤 10 中的图像 2,2
    • Use the two screws and the Torx screwdriver to secure the parts.
  11. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Attach the wheel: 步骤 11 中的图像 1,1
    • Click the wheel back onto the frame.
  12. Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: 步骤 12 中的图像 1,2 Bugaboo Cameleon 1 and 3 Swivel Wheel Lock Replacement, Put the stroller the right side up.: 步骤 12 中的图像 2,2
    • The repair is now finished. Flip the frame back onto four wheels.
    • Place the seat back onto the frame.
终点
另外一个人完成了本指南。
附加文件
Rebecca Dowling
于04/24/18注册
692 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 2,549
