跳转到主内容
Brother XR-40 Stitch Select Knob Replacement
你所需要的
  1. Brother XR-40 Stitch Select Knob Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Stitch Select Knob Replacement: 步骤 2 中的图像 1,1
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Stitch Select Knob Replacement: 步骤 3 中的图像 1,1
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Stitch Select Knob Replacement: 步骤 4 中的图像 1,1
    • Remove the bottom panel.
  5. Brother XR-40 Stitch Select Knob Replacement: 步骤 5 中的图像 1,1
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Stitch Select Knob Replacement, Stitch Select Knob: 步骤 6 中的图像 1,1
    • Adjust the knob to gain access to the phillips head screw.
  7. Brother XR-40 Stitch Select Knob Replacement: 步骤 7 中的图像 1,1
    • Remove the 14mm Phillips #2 screw.
  8. Brother XR-40 Stitch Select Knob Replacement: 步骤 8 中的图像 1,1
    • Remove the knob.
结论
另外一个人完成了本指南。
Kevin Bickers
于02/05/14注册
673 声望
创作了4篇指南
团队
Cal Poly, Team 2-12, Amido Winter 2014 Cal Poly, Team 2-12, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G12
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 1,464
