跳转到主内容
Brother XM3700 Broken Needle Replacement
你所需要的
  1. Brother XM3700 Broken Needle Replacement, Broken Needle: 步骤 1 中的图像 1,3 Brother XM3700 Broken Needle Replacement, Broken Needle: 步骤 1 中的图像 2,3 Brother XM3700 Broken Needle Replacement, Broken Needle: 步骤 1 中的图像 3,3
    • Adjust the needle with the handwheel towards you until it is at the highest position, as indicated by the silver thread take-up lever.
  2. Brother XM3700 Broken Needle Replacement: 步骤 2 中的图像 1,2 Brother XM3700 Broken Needle Replacement: 步骤 2 中的图像 2,2
    • Unscrew the bolt that holds the needle in place using either the tool that came with your Brother machine, or a small flat object like a coin.
  3. Brother XM3700 Broken Needle Replacement: 步骤 3 中的图像 1,2 Brother XM3700 Broken Needle Replacement: 步骤 3 中的图像 2,2
    • Remove the broken needle stem from the machine, and dispose of it carefully.
  4. Brother XM3700 Broken Needle Replacement: 步骤 4 中的图像 1,2 Brother XM3700 Broken Needle Replacement: 步骤 4 中的图像 2,2
    • Unthread the broken needle tip from the thread, and dispose of carefully.
  5. Brother XM3700 Broken Needle Replacement: 步骤 5 中的图像 1,2 Brother XM3700 Broken Needle Replacement: 步骤 5 中的图像 2,2
    • Select a Brother brand needle, using the needle size that works well with your fabric.
  6. Brother XM3700 Broken Needle Replacement: 步骤 6 中的图像 1,2 Brother XM3700 Broken Needle Replacement: 步骤 6 中的图像 2,2
    • Insert the needle with the flat side of the stem facing the back of the machine.
  7. Brother XM3700 Broken Needle Replacement: 步骤 7 中的图像 1,1
    • Screw the bolt in first with your fingers and then with the tool until the needle is tightly secured.
  8. Brother XM3700 Broken Needle Replacement: 步骤 8 中的图像 1,2 Brother XM3700 Broken Needle Replacement: 步骤 8 中的图像 2,2
    • Rethread the needle and pull the thread through the back.
结论
Congratulations! You have successfully replaced your broken needle. Happy sewing!
另外一个人完成了本指南。
Nadya Verick
于02/07/23注册
178 声望
撰写一个指南
团队
UC Davis, Team 1-6, Andersen Winter 2023 UC Davis, Team 1-6, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S1G6
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 427
