跳转到主内容
简介
This guide will walk you through the process of replacing a dead or broken LCD screen on a Brother PT-D200.
配件
没有特定配件。
  1. Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Remove the six AAA batteries.
    • Remove the six AAA batteries.
  3. Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  5. Gently pull out the ribbon cable from the circuit board.
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  6. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  7. Remove two-pin plastic connector from the circuit board.
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  8. Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver. Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
    • Remove the two 3/16" screws from the circuit board using the Helping Hand 1/4" screwdriver.
  9. Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
    • Release the two black clips that hold the LCD cable ribbon in place. To release, pull the clips towards the ribbon.
  10. Disconnect the LCD ribbon cable from the circuit board.
    • Disconnect the LCD ribbon cable from the circuit board.
  11. On the top portion of the device there are four grey clips locking the faceplate in place.  The two top clips are circled in the image. The two others are located in the other corners of the device.
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  12. Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off. Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
  13. Peel off the rubber keyboard of the device. Peel off the rubber keyboard of the device.
    • Peel off the rubber keyboard of the device.
  14. Lift the LCD screen out of place. Lift the LCD screen out of place.
    • Lift the LCD screen out of place.
结论
Jeston Mitchell
于2014年01月24日注册
308 信誉积分
创作了3篇指南
团队
Cal Poly, Team 13-16, Regan Winter 2014 Cal Poly, Team 13-16, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G16
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 15
总计 980
