当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
Remove the six AAA batteries.
Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
Gently pull out the ribbon cable from the circuit board.
The ribbon cable is very fragile.
Remove two-pin plastic connector from the circuit board.
Gently pull the two-pin connector from the circuit board to avoid damaging the board.
On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与5其他贡献者
于01/24/14注册
301 声望
创作了3篇指南
徽章: 6
+ 3更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 658
