跳转到主内容
Brother PT-D200 Faceplate Replacement
你所需要的
  1. Brother PT-D200 Faceplate Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-D200 Faceplate Replacement: 步骤 2 中的图像 1,1
    • Remove the six AAA batteries.
  3. Brother PT-D200 Faceplate Replacement, Back of Device: 步骤 3 中的图像 1,1
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Brother PT-D200 Faceplate Replacement: 步骤 4 中的图像 1,1
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  5. Brother PT-D200 Faceplate Replacement, Circuit Board Cables: 步骤 5 中的图像 1,1
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  6. Brother PT-D200 Faceplate Replacement: 步骤 6 中的图像 1,1
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  7. Brother PT-D200 Faceplate Replacement, Face Plate: 步骤 7 中的图像 1,1
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  8. Brother PT-D200 Faceplate Replacement: 步骤 8 中的图像 1,2 Brother PT-D200 Faceplate Replacement: 步骤 8 中的图像 2,2
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
结论
另外一个人完成了本指南。
[deleted]
于01/24/14注册
301 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 644
