跳转到主内容
简介
This guide will walk you through the process of replacing a dull or broken cutter blade on a Brother PT-D200.
  1. Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you. Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  2. PC 笔记本电池
    An easy fix for a big power boost.
    现在开始购物
    PC 笔记本电池
    现在开始购物
  3. Locate the cutter blade unit (mint green) as shown in the picture.
    • Locate the cutter blade unit (mint green) as shown in the picture.
  4. Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed. The blade is sharp.
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
    • The blade is sharp.
结论
Blaire McCreary
于2014年01月24日注册
201 信誉积分
创作了2篇指南
团队
Cal Poly, Team 13-16, Regan Winter 2014 Cal Poly, Team 13-16, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G16
3 名成员
创作了6篇指南
Where can you order the replacement blade?
mistymeziere - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 30
总计 1,252
