跳转到主内容
Brother PT-90 Personal Labeler Disassembly
你所需要的
  1. Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: 步骤 1 中的图像 1,2 Brother PT-90 Personal Labeler Disassembly, Brother PT-90 Personal Labeler Disassembly: 步骤 1 中的图像 2,2
    • Start with your device off. The screen should be blank and not displaying anything.
    • Turn the device over so it's resting face down.
    • You should be able to see the model name of the label-maker, as well as a window in which you can view the label cartridge.
  2. Brother PT-90 Personal Labeler Disassembly: 步骤 2 中的图像 1,3 Brother PT-90 Personal Labeler Disassembly: 步骤 2 中的图像 2,3 Brother PT-90 Personal Labeler Disassembly: 步骤 2 中的图像 3,3
    • Using your thumb, press in and then upward on the fastener at the top of the device. The back of the device should come off easily.
    • Remove the 4 batteries located on the left side of the device.
  3. Brother PT-90 Personal Labeler Disassembly: 步骤 3 中的图像 1,3 Brother PT-90 Personal Labeler Disassembly: 步骤 3 中的图像 2,3 Brother PT-90 Personal Labeler Disassembly: 步骤 3 中的图像 3,3
    • To remove the label cartridge from the device, use a plastic opening tool from your iFixit tool kit.
  4. Brother PT-90 Personal Labeler Disassembly: 步骤 4 中的图像 1,3 Brother PT-90 Personal Labeler Disassembly: 步骤 4 中的图像 2,3 Brother PT-90 Personal Labeler Disassembly: 步骤 4 中的图像 3,3
    • Attach the J1 Screwdriver Bit to the extension tool from your tool kit.
    • Remove all of the screws from the back of the device.
  5. Brother PT-90 Personal Labeler Disassembly: 步骤 5 中的图像 1,2 Brother PT-90 Personal Labeler Disassembly: 步骤 5 中的图像 2,2
    • Once the screws have been removed, press as shown on the fastener.
    • Carefully open the device.
终点
另外一个人完成了本指南。
团队
University of Maine, Team 2-1, Diaz Fall 2016 University of Maine, Team 2-1, Diaz Fall 2016 的会员
UMAINE-DIAZ-F16S2G1
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 29
总计 809
