本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide provides step by step instructions for replacing the tape cassette in a Brother PT-129 when the cassette is empty and in need of more tape to function. Before beginning, make sure the device is powered off to easily disassemble.
Flip the label maker onto its backside and press down on the circle part with ridges located at the top.
Gently pull the label maker apart. It will split in half.
Now that you have inserted the tape, the batteries may be added back. Close the label maker, press the power button, then it is ready for use.
After installing the tape press the up key to feed the tape, then the cutter button to cut the tape off.
