跳转到主内容
Brother PT-1290 Tape Cassette Replacement
  1. Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: 步骤 1 中的图像 1,2 Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: 步骤 1 中的图像 2,2
    • There is a plastic tab located on the back of the label maker near the top. The tab has ridges on it to help you identify where to press. Push on this tab to release the back of the label maker.
    • Gently pull the label maker apart - it will split in half.
    • Be careful! The electronics inside are very sensitive and easily damaged.
  2. Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: 步骤 2 中的图像 1,2 Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: 步骤 2 中的图像 2,2
    • Remove the AAA batteries before you proceed on to replacing the tape cassette.
  3. Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: 步骤 3 中的图像 1,2 Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: 步骤 3 中的图像 2,2
    • Align and insert a new tape cassette. Make sure the center of the cassette snaps into place. The tape must feed between the tape guides.
    • If the ribbon has become too loose, use your finger to turn the white wheel in the direction of the arrow on the tape cassette. This will wind up any excess tape.
    • Only use Brother TZ tapes with this machine.
  4. Brother PT-1290 Tape Cassette Replacement, Evaluating: 步骤 4 中的图像 1,1
    • Place the batteries back inside, then close the cover.
    • Check that all six batteries are inserted correctly.
  5. Brother PT-1290 Tape Cassette Replacement, Feeding Tape.: 步骤 5 中的图像 1,1
    • To test the new cassette, make a new label. Press "Shift" and "Print" to feed the tape, then use the cutting lever on the upper-right corner of the machine.
结论
Lorraine Canez
于10/25/14注册
318 声望
创作了3篇指南
团队
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G4
3 名成员
创作了6篇指南
一条评论
Wie wird die Kassette eingesetzt
Uwe Seiler - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 32
总计 19,744
