跳转到主内容
Brother PT-1290 LCD Screen Replacement
你所需要的
  1. Brother PT-1290 LCD Screen Replacement, Tape Cassette: 步骤 1 中的图像 1,2 Brother PT-1290 LCD Screen Replacement, Tape Cassette: 步骤 1 中的图像 2,2
    • There is a plastic tab located on the back of the label maker near the top. The tab has ridges on it to help you identify where to press. Push on this tab to release the back of the label maker.
    • Gently pull the label maker apart - it will split in half.
    • Be careful! The electronics inside are very sensitive and easily damaged.
  2. Brother PT-1290 LCD Screen Replacement: 步骤 2 中的图像 1,2 Brother PT-1290 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the AAA batteries before you proceed on to replacing the tape cassette.
  3. Brother PT-1290 LCD Screen Replacement: 步骤 3 中的图像 1,2 Brother PT-1290 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Align and insert a new tape cassette. Make sure the center of the cassette snaps into place. The tape must feed between the tape guides.
    • If the ribbon has become too loose, use your finger to turn the white wheel in the direction of the arrow on the tape cassette. This will wind up any excess tape.
    • Only use Brother TZ tapes with this machine.
  4. Brother PT-1290 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Place the batteries back inside, then close the cover.
    • Check that all six batteries are inserted correctly.
  5. Brother PT-1290 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • To test the new cassette, make a new label. Press "Shift" and "Print" to feed the tape, then use the cutting lever on the upper-right corner of the machine.
  6. Brother PT-1290 LCD Screen Replacement, Keyboard: 步骤 6 中的图像 1,3 Brother PT-1290 LCD Screen Replacement, Keyboard: 步骤 6 中的图像 2,3 Brother PT-1290 LCD Screen Replacement, Keyboard: 步骤 6 中的图像 3,3
    • Turn the device to its side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  7. Brother PT-1290 LCD Screen Replacement: 步骤 7 中的图像 1,3 Brother PT-1290 LCD Screen Replacement: 步骤 7 中的图像 2,3 Brother PT-1290 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Remove back of device and set aside.
  8. Brother PT-1290 LCD Screen Replacement: 步骤 8 中的图像 1,3 Brother PT-1290 LCD Screen Replacement: 步骤 8 中的图像 2,3 Brother PT-1290 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  9. Brother PT-1290 LCD Screen Replacement: 步骤 9 中的图像 1,3 Brother PT-1290 LCD Screen Replacement: 步骤 9 中的图像 2,3 Brother PT-1290 LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  10. Brother PT-1290 LCD Screen Replacement: 步骤 10 中的图像 1,3 Brother PT-1290 LCD Screen Replacement: 步骤 10 中的图像 2,3 Brother PT-1290 LCD Screen Replacement: 步骤 10 中的图像 3,3
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  11. Brother PT-1290 LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 1,3 Brother PT-1290 LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 2,3 Brother PT-1290 LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 3,3
    • Remove the five screws that secure the plate using a Phillips #00 screwdriver.
    • One screw has a very narrow access; you will need a thinner screwdriver.
  12. Brother PT-1290 LCD Screen Replacement: 步骤 12 中的图像 1,3 Brother PT-1290 LCD Screen Replacement: 步骤 12 中的图像 2,3 Brother PT-1290 LCD Screen Replacement: 步骤 12 中的图像 3,3
    • Remove three screws to be able to lift the keyboard.
    • Remove the small metal plate on top of the black connector with the red and black cables.
  13. Brother PT-1290 LCD Screen Replacement: 步骤 13 中的图像 1,2 Brother PT-1290 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Unhook the connector with the orange and blue wire.
    • There is also a hook that holds the yellow, red, orange and green cables; the spudger will be all you need to slide them out to unhook them.
    • The black connector with the red and black cables has to be removed as well.
  14. Brother PT-1290 LCD Screen Replacement: 步骤 14 中的图像 1,3 Brother PT-1290 LCD Screen Replacement: 步骤 14 中的图像 2,3 Brother PT-1290 LCD Screen Replacement: 步骤 14 中的图像 3,3
    • Hold the keyboard, making sure the four hooks are properly loose to avoid breaking them.
    • Pull it out gently but firmly.
    • Make sure once it becomes loose, you can proceed to remove the LCD which is being held by two more hooks marked with orange circles. You will need the Spudger to hold them back while pulling the screen with your other hand.
  15. Brother PT-1290 LCD Screen Replacement: 步骤 15 中的图像 1,3 Brother PT-1290 LCD Screen Replacement: 步骤 15 中的图像 2,3 Brother PT-1290 LCD Screen Replacement: 步骤 15 中的图像 3,3
    • If the face plate doesn't get removed, it will be close to impossible to remove the LCD or you'll find yourself breaking some of the hooks that are holding it on place.
    • Remove and replace the LCD screen making sure the display data cable doesn't get damaged in the process.
    • Follow the steps backwards in the order they were removed, to be able to put the parts together and remain your printing job.
结论
另外一个人完成了本指南。
Yadira Jones
于10/25/14注册
273 声望
创作了2篇指南
团队
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 2,249
