简介
This guide will take you through the broken/damaged keyboard to the P-Touch step by step.
你所需要的
Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
Use a spudger to aid in removing the keyboard.
Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
