跳转到主内容
Brother PT-1290 Battery/AC Adapter Replacment
  1. Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: 步骤 1 中的图像 1,3 Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: 步骤 1 中的图像 2,3 Brother PT-1290 Battery/AC Adapter Replacment, Brother PT-1290 Battery/AC Adapter: 步骤 1 中的图像 3,3
    • First, flip over your label maker and push down on the top part(by the face plate) and push on the circle part with ridges. Next open the label maker carefully to prevent any damage.
  2. Brother PT-1290 Battery/AC Adapter Replacment: 步骤 2 中的图像 1,1
    • Once the label maker is open, remove the six AAA drained batteries.
    • If your using an AC adapter, replace the old one with the new HQRP adapter.
    • If you see white on the batteries, that would be corrosion. Be careful when disposing.
  3. Brother PT-1290 Battery/AC Adapter Replacment: 步骤 3 中的图像 1,3 Brother PT-1290 Battery/AC Adapter Replacment: 步骤 3 中的图像 2,3 Brother PT-1290 Battery/AC Adapter Replacment: 步骤 3 中的图像 3,3
    • Now place in the new six AAA batteries.
    • Make sure the batteries are correctly in and touching the golden prongs.
结论
Lorraine Canez
于10/25/14注册
318 声望
创作了3篇指南
团队
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 841
