跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
In this guide, you will see how to fix your broken/damaged face plate on your Brother PT-1290.
  1. Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries. Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries. Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Remove back of device and set aside. Remove back of device and set aside. Remove back of device and set aside.
    • Remove back of device and set aside.
  3. Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable. Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable. Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside. Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside. Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  6. Use a spudger to aid in removing the keyboard. Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing. Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  7. Now that you have removed your keyboard. Turn the device over carefully. Pop of LCD black cover. Use the spudger to gently press out the LCD screen.
    • Now that you have removed your keyboard. Turn the device over carefully.
    • Pop of LCD black cover.
    • Use the spudger to gently press out the LCD screen.
  8. Change out old damaged face plate with your new face plate.
    • Change out old damaged face plate with your new face plate.
结论
Lorraine Canez
于2014年10月25日注册
308 信誉积分
创作了3篇指南
团队
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 的会员
GCC-JOHNSON-F14S1G4
3 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 94
