跳转到主内容
Brother PT-110 Printer Motor Replacement
你所需要的
  1. Brother PT-110 Printer Motor Replacement, Batteries: 步骤 1 中的图像 1,2 Brother PT-110 Printer Motor Replacement, Batteries: 步骤 1 中的图像 2,2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Printer Motor Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries.
  3. Brother PT-110 Printer Motor Replacement, Back Plate: 步骤 3 中的图像 1,2 Brother PT-110 Printer Motor Replacement, Back Plate: 步骤 3 中的图像 2,2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Printer Motor Replacement: 步骤 4 中的图像 1,1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Printer Motor Replacement: 步骤 5 中的图像 1,1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Printer Motor Replacement: 步骤 6 中的图像 1,1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Printer Motor Replacement: 步骤 7 中的图像 1,2 Brother PT-110 Printer Motor Replacement: 步骤 7 中的图像 2,2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Printer Motor Replacement: 步骤 8 中的图像 1,3 Brother PT-110 Printer Motor Replacement: 步骤 8 中的图像 2,3 Brother PT-110 Printer Motor Replacement: 步骤 8 中的图像 3,3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Printer Motor Replacement, Printer Motor: 步骤 9 中的图像 1,1
    • Remove the motor housing.
  10. Brother PT-110 Printer Motor Replacement: 步骤 10 中的图像 1,2 Brother PT-110 Printer Motor Replacement: 步骤 10 中的图像 2,2
    • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
    • Total: 2 x Screws
  11. Brother PT-110 Printer Motor Replacement: 步骤 11 中的图像 1,1
    • Remove the motor.
结论
Kimberly Larsen
于09/28/16注册
237 声望
创作了5篇指南
团队
IUPUI, Team 1-1, Harley Fall 2016 IUPUI, Team 1-1, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S1G1
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 821
