跳转到主内容
Brother PT-110 Print Roller Lever Replacement
你所需要的
  1. Brother PT-110 Print Roller Lever Replacement, Batteries: 步骤 1 中的图像 1,2 Brother PT-110 Print Roller Lever Replacement, Batteries: 步骤 1 中的图像 2,2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Print Roller Lever Replacement: 步骤 2 中的图像 1,1
    • Remove the batteries.
  3. Brother PT-110 Print Roller Lever Replacement, Back Plate: 步骤 3 中的图像 1,2 Brother PT-110 Print Roller Lever Replacement, Back Plate: 步骤 3 中的图像 2,2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Print Roller Lever Replacement: 步骤 4 中的图像 1,1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Print Roller Lever Replacement: 步骤 5 中的图像 1,1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Print Roller Lever Replacement: 步骤 6 中的图像 1,1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Print Roller Lever Replacement: 步骤 7 中的图像 1,2 Brother PT-110 Print Roller Lever Replacement: 步骤 7 中的图像 2,2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Print Roller Lever Replacement: 步骤 8 中的图像 1,3 Brother PT-110 Print Roller Lever Replacement: 步骤 8 中的图像 2,3 Brother PT-110 Print Roller Lever Replacement: 步骤 8 中的图像 3,3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Print Roller Lever Replacement, Print Roller Lever: 步骤 9 中的图像 1,1
    • Using the metal spudger, swivel the pin so that the print roller lever loosens.
  10. Brother PT-110 Print Roller Lever Replacement: 步骤 10 中的图像 1,1
    • Gently pull the print roller lever out.
结论
2等其他人完成本指南。
Kimberly Larsen
于09/28/16注册
237 声望
创作了5篇指南
团队
IUPUI, Team 1-1, Harley Fall 2016 IUPUI, Team 1-1, Harley Fall 2016 的会员
IUPUI-HARLEY-F16S1G1
3 名成员
创作了7篇指南
5条评论
Hi everybody ,does anyone knows were I can by such a lever ?
TBH
Daniel Verkest - 回复
BONJOUR, (I’m French)
Same question: does anyone knows were I can by such a lever ?
Pegase M - 回复
Did anyone find a source for this part?
Erik Carlson - 回复
Unfortunately very discontinued. Until someone adds it to thingverse there's not much that can be done.
UN8026001 ROLLER HOLDER ASSY PT100/110
UN8031001 ROLLER HOLDER SPRING PT100
UN8032000 ROLLER RELEASE LEVER PT100/110
Michael Krieger - 回复
I can fix these by using plastic weld to rebuild the edging. I was totally successful.
George Pede - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,732
