跳转到主内容
Brother PT-1010 Cassette Tape Replacement
你所需要的
  1. Brother PT-1010 Cassette Tape Replacement, Remove Back Cover: 步骤 1 中的图像 1,1
    • Remove the back cover of the device by simultaneously pressing down on the indication arrows on the top center, then pulling toward you.
  2. Brother PT-1010 Cassette Tape Replacement, Insert Tape Cassette: 步骤 2 中的图像 1,1
    • Brother TZ tape is required for this replacement process. We don't have the tape cassette but you should be able to insert tape cassette into the red marked area as shown in the picture.
    • Insert tape cassette into the red marked area as shown in the picture.
    • Make sure the cassette snaps into place by applying a small amount of pressure.
结论
Haley Sweet
于10/30/14注册
460 声望
创作了4篇指南
团队
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 的会员
BU-WILLIAMS-F14S4G4
4 名成员
创作了4篇指南
3条评论
So if you've replaced the cassette and it still won't print now what??
Sara Mullaney - 回复
This was supposed to help with model PT-450D which looks nothing like this. Please help. I can’t REMOVE / replace the cassette !!! It is STUCK inside the label printer!
af4k - 回复
I have a PT-1880 model and replaced the cassette, but whenever I type something to label something, the label comes out blank. Can someone help me on this? I’ve been needing help on this for a while now.
Yael Rzoque - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 3,246
