跳转到主内容
Brother MFC-J4420DW opening procedure
你所需要的
  1. Brother MFC-J4420DW opening procedure, Removing hood holder: 步骤 1 中的图像 1,3 Brother MFC-J4420DW opening procedure, Removing hood holder: 步骤 1 中的图像 2,3 Brother MFC-J4420DW opening procedure, Removing hood holder: 步骤 1 中的图像 3,3
    • Disconnect the power cord of the printer
    • Open the printer as you would to access the USB port.
    • Pull out the rear end of the hood holder (see picture two). After that you can remove the top part of the hood holder.
    • Now remove the hood holder completely.
    • It is quite useful to put the printer near something so that you can lean the top against something, for example a wall.
  2. Brother MFC-J4420DW opening procedure, Removing cables connected to the top part of the printer: 步骤 2 中的图像 1,3 Brother MFC-J4420DW opening procedure, Removing cables connected to the top part of the printer: 步骤 2 中的图像 2,3 Brother MFC-J4420DW opening procedure, Removing cables connected to the top part of the printer: 步骤 2 中的图像 3,3
    • Next remove the cover on the left side of the printer (lift the right side of the cover first).
    • Unplug the black ribbon cable, the blue and the white plugs from its sockets and unscrew the cable which is attached with a screw (see second image)
    • Remove the red and white plugs from its sockets as shown in picture three.
  3. Brother MFC-J4420DW opening procedure, Remove the top part of the printer: 步骤 3 中的图像 1,3 Brother MFC-J4420DW opening procedure, Remove the top part of the printer: 步骤 3 中的图像 2,3 Brother MFC-J4420DW opening procedure, Remove the top part of the printer: 步骤 3 中的图像 3,3
    • Flip the plastic part shown in picture one up to the top part of the printer
    • Now you can easily remove the top of the printer by pushing it away from the printer (not up).
  4. Brother MFC-J4420DW opening procedure, Remove cover: 步骤 4 中的图像 1,2 Brother MFC-J4420DW opening procedure, Remove cover: 步骤 4 中的图像 2,2
    • Remove the screws connecting the black plastic cover to the printer (see image)
    • Remove the cover
终点
另外一个人完成了本指南。
Matthias Loikasek
于11/24/16注册
1,373 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 35
过去 30 天: 119
总计 1,630
