跳转到主内容
Brother MFC-9130CW Ink Cartridge Replacement
你所需要的
  1. Brother MFC-9130CW Ink Cartridge Replacement, Ink Cartridge Replacement: 步骤 1 中的图像 1,1
    • Press the power button on the printer for a couple of seconds to turn it off.
  2. Brother MFC-9130CW Ink Cartridge Replacement: 步骤 2 中的图像 1,2 Brother MFC-9130CW Ink Cartridge Replacement: 步骤 2 中的图像 2,2
    • Press the latch beneath the paper output area and lift it to access the ink compartment.
  3. Brother MFC-9130CW Ink Cartridge Replacement: 步骤 3 中的图像 1,1
    • Identify the specific ink color you wish to replace among the available cartridges in the ink compartment.
  4. Brother MFC-9130CW Ink Cartridge Replacement: 步骤 4 中的图像 1,2 Brother MFC-9130CW Ink Cartridge Replacement: 步骤 4 中的图像 2,2
    • Pull each ink cartridge tray out of its slot using the center handle.
  5. Brother MFC-9130CW Ink Cartridge Replacement: 步骤 5 中的图像 1,2 Brother MFC-9130CW Ink Cartridge Replacement: 步骤 5 中的图像 2,2
    • Place the new ink cartridge on a clean surface.
    • Release the orange cover, as shown on the photo.
    • To prevent making a mess, set a paper towel on the counter or table in case of a spill during the replacement process.
  6. Brother MFC-9130CW Ink Cartridge Replacement: 步骤 6 中的图像 1,2 Brother MFC-9130CW Ink Cartridge Replacement: 步骤 6 中的图像 2,2
    • Place the cartridge in the tray.
    • Gently press down on the ink tray with your thumb.
    • You should hear a click, ensuring that the new ink cartridge is secure in its place.
  7. Brother MFC-9130CW Ink Cartridge Replacement: 步骤 7 中的图像 1,3 Brother MFC-9130CW Ink Cartridge Replacement: 步骤 7 中的图像 2,3 Brother MFC-9130CW Ink Cartridge Replacement: 步骤 7 中的图像 3,3
    • Slide the ink tray back into its original position within the printer.
    • Make sure it is properly aligned and secure within the compartment.
    • Once the ink tray is secured, press the ink compartment latch with your thumb, and gently close the lid.
  8. Brother MFC-9130CW Ink Cartridge Replacement: 步骤 8 中的图像 1,1
    • Press the power button for a couple of seconds to turn the printer back on.
    • Print a couple of test copies to ensure the toner cartridge replacement was a success.
结论
To reassemble your device, follow these instructions in the given order.
另外一个人完成了本指南。
Kamaljot
于01/08/24注册
184 声望
撰写一个指南
团队
1指南评论
One step is missing : release the orange cover.
Artefil - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 49
总计 561
