跳转到主内容
加入维修社区 - 创建账户
Brother MFC-490CW Wireless module Replacement
你所需要的
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: 步骤 1 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: 步骤 2 中的图像 1,3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: 步骤 2 中的图像 2,3 Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: 步骤 2 中的图像 3,3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: 步骤 3 中的图像 1,1
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: 步骤 4 中的图像 1,3 Brother MFC-490CW Wireless module Replacement: 步骤 4 中的图像 2,3 Brother MFC-490CW Wireless module Replacement: 步骤 4 中的图像 3,3
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: 步骤 5 中的图像 1,2 Brother MFC-490CW Wireless module Replacement: 步骤 5 中的图像 2,2
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: 步骤 6 中的图像 1,3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: 步骤 6 中的图像 2,3 Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: 步骤 6 中的图像 3,3
    • Separate the two clips that hold the module in place.
    • Lift up the module.
结论
To reassemble your wireless module, follow these instructions in reverse order.
Matt
于10/30/14注册
64 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G4
3 名成员
创作了11篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 45
总计 2,253
