跳转到主内容
Brother MFC-490CW Scanning Glass Replacement
你所需要的
  1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: 步骤 1 中的图像 1,3 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: 步骤 1 中的图像 2,3 Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: 步骤 1 中的图像 3,3
    • Twist green section to allow the scanner head to have a full range of motion.
  2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: 步骤 2 中的图像 1,3 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: 步骤 2 中的图像 2,3 Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: 步骤 2 中的图像 3,3
    • To remove scanner head, open it halfway as possible and slide the hinges out of place and the head will be removed.
  3. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: 步骤 3 中的图像 1,3 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: 步骤 3 中的图像 2,3 Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: 步骤 3 中的图像 3,3
    • The panels to expose the cords will become exposed when the head is removed.
    • Pull all colored cords from the printer and unscrew the other wire to be fully removed.
    • Pull the black tab from the printer to remove.
  4. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: 步骤 4 中的图像 1,2 Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: 步骤 4 中的图像 2,2
    • Once scanner is free from the printer remove all the screws on the bottom base
    • Use a #2 Philips head screw driver to remove the two 12.1mm screws.
  5. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: 步骤 5 中的图像 1,3 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: 步骤 5 中的图像 2,3 Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: 步骤 5 中的图像 3,3
    • To separate the base from the glass hold upright and separate along the edge where you removed the screws.
    • Use hands to expose the glass.
    • Keep track flat once glass is removed as to not lose little parts.
  6. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: 步骤 6 中的图像 1,3 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: 步骤 6 中的图像 2,3 Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: 步骤 6 中的图像 3,3
    • Disconnect the glass from the tracks.
    • Remove old or broken glass.
    • Replace with adhesive tape along the bottom of the header and reassemble.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G4
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 26
过去 30 天: 82
总计 3,743
