简介
If you need to access the internal components of the Brother MFC-490CW, you will have to remove the front panel of the Brother MFC-490CW. Use this guide to remove the front panel of this device.
你所需要的
Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
Lift up the front panel from the device.
Gently lift up and disconnect the data cables that attach the panel to the printer.
To reassemble the front panel, follow these instructions in reverse order.
2等其他人完成本指南。
一条评论
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
