跳转到主内容
Brother MFC-490CW Front Panel Replacement
你所需要的
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: 步骤 1 中的图像 1,1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: 步骤 2 中的图像 1,3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: 步骤 2 中的图像 2,3 Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: 步骤 2 中的图像 3,3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
结论
To reassemble the front panel, follow these instructions in reverse order.
2等其他人完成本指南。
Matt
于10/30/14注册
64 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G4
3 名成员
创作了11篇指南
1指南评论
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 46
总计 2,032
