跳转到主内容
加入维修社区 - 创建账户
Brother IntelliFax-2840 Control Panel Replacement
你所需要的
  1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: 步骤 1 中的图像 1,1
    • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
    询问修复机器人
    添加评论
  2. Brother IntelliFax-2840 Control Panel Replacement: 步骤 2 中的图像 1,2 Brother IntelliFax-2840 Control Panel Replacement: 步骤 2 中的图像 2,2
    • Gently pull the ADF up and away from the machine.
    询问修复机器人
    添加评论
  3. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: 步骤 3 中的图像 1,2 Brother IntelliFax-2840 Control Panel Replacement, Control Panel: 步骤 3 中的图像 2,2
    • Gently lift up the control panel.
    询问修复机器人
    添加评论
  4. Brother IntelliFax-2840 Control Panel Replacement: 步骤 4 中的图像 1,3 Brother IntelliFax-2840 Control Panel Replacement: 步骤 4 中的图像 2,3 Brother IntelliFax-2840 Control Panel Replacement: 步骤 4 中的图像 3,3
    • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
    • Repeat for the left side control arm.
    • You can make this task easier by taking the handset out of the cradle and setting it aside.
    询问修复机器人
    添加评论
  5. Brother IntelliFax-2840 Control Panel Replacement: 步骤 5 中的图像 1,2 Brother IntelliFax-2840 Control Panel Replacement: 步骤 5 中的图像 2,2
    • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
    • Lifting from the front edge, gently flip up the control panel.
    询问修复机器人
    添加评论
  6. Brother IntelliFax-2840 Control Panel Replacement: 步骤 6 中的图像 1,1
    • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
    询问修复机器人
    添加评论
  7. Brother IntelliFax-2840 Control Panel Replacement: 步骤 7 中的图像 1,1
    • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
    • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
    询问修复机器人
    添加评论
  8. Brother IntelliFax-2840 Control Panel Replacement: 步骤 8 中的图像 1,2 Brother IntelliFax-2840 Control Panel Replacement: 步骤 8 中的图像 2,2
    • Separate the rear control panel cover from the control panel.
    询问修复机器人
    添加评论
  9. Brother IntelliFax-2840 Control Panel Replacement: 步骤 9 中的图像 1,2 Brother IntelliFax-2840 Control Panel Replacement: 步骤 9 中的图像 2,2
    • Gently pull the control panel cable straight out from its connector.
    • The control panel should now come free.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Geoff Wacker
于09/30/13注册
92,880 声望
创作了89篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 4,594
