跳转到主内容
Brother Boutique 761 Needle Replacement
你所需要的
  1. Brother Boutique 761 Needle Replacement, Needle: 步骤 1 中的图像 1,2 Brother Boutique 761 Needle Replacement, Needle: 步骤 1 中的图像 2,2
    • Locate the screw and turn the screw counterclockwise (left).
    • Loosen the screw gently and carefully remove the needle.
  2. Brother Boutique 761 Needle Replacement: 步骤 2 中的图像 1,1
    • Remove the faulty needle and replace it with a new needle.
  3. Brother Boutique 761 Needle Replacement: 步骤 3 中的图像 1,1
    • Take the new needle, place the needle carefully at the base of the opening.
    • Secure the new needle, locate the screw and turn it clockwise (right) until tightened.
  4. Brother Boutique 761 Needle Replacement: 步骤 4 中的图像 1,2 Brother Boutique 761 Needle Replacement: 步骤 4 中的图像 2,2
    • Secure the needle once again. We will start to re-thread the sewing machine.
    • Place the thread on the lever with the loose piece of thread on the outside.
  5. Brother Boutique 761 Needle Replacement: 步骤 5 中的图像 1,1
    • Take the loose piece of thread and place it through the hood that is present at the top of the sewing machine.
  6. Brother Boutique 761 Needle Replacement: 步骤 6 中的图像 1,1
    • Pull the thread down towards you in the open on the front of your machine.
    • Hook the thread at the end of the opening.
  7. Brother Boutique 761 Needle Replacement: 步骤 7 中的图像 1,1
    • Take your thread and locate the hole that is in the needle.
    • Put the thread through the hole.
  8. Brother Boutique 761 Needle Replacement: 步骤 8 中的图像 1,1
    • Make sure that the thread is through the needle. Pull the thread down underneath the presser foot.
    • You have now finished replacing the needle and rethreading the sewing machine.
结论
In conclusion, fixing a needle on a sewing machine is a fundamental skill for any person using a sewing machine. By following a few simple steps, you can ensure that the needle is securely and correctly positioned, leading to smooth and accurate stitching.
Erin Juarez
于10/23/23注册
157 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 25
总计 143
