跳转到主内容
加入维修社区 - 创建账户
Broken PVC Pipe Cleanout Replacement
你所需要的
  1. Broken PVC Pipe Cleanout Replacement, PVC Hub Combo Wye Fitting: 步骤 1 中的图像 1,3 Broken PVC Pipe Cleanout Replacement, PVC Hub Combo Wye Fitting: 步骤 1 中的图像 2,3 Broken PVC Pipe Cleanout Replacement, PVC Hub Combo Wye Fitting: 步骤 1 中的图像 3,3
    • Using the shovel, dig out around base of pipe.
  2. Broken PVC Pipe Cleanout Replacement: 步骤 2 中的图像 1,3 Broken PVC Pipe Cleanout Replacement: 步骤 2 中的图像 2,3 Broken PVC Pipe Cleanout Replacement: 步骤 2 中的图像 3,3
    • Using the hack saw, cut the broken pipe at the joint connections.
  3. Broken PVC Pipe Cleanout Replacement: 步骤 3 中的图像 1,3 Broken PVC Pipe Cleanout Replacement: 步骤 3 中的图像 2,3 Broken PVC Pipe Cleanout Replacement: 步骤 3 中的图像 3,3
    • Using the brush and towel, clean the pipe ends at least one inch on both ends.
  4. Broken PVC Pipe Cleanout Replacement: 步骤 4 中的图像 1,2 Broken PVC Pipe Cleanout Replacement: 步骤 4 中的图像 2,2
    • Fit all PVC pieces on to ensure that they all fit before you cement them together.
  5. Broken PVC Pipe Cleanout Replacement: 步骤 5 中的图像 1,3 Broken PVC Pipe Cleanout Replacement: 步骤 5 中的图像 2,3 Broken PVC Pipe Cleanout Replacement: 步骤 5 中的图像 3,3
    • With the measuring tape, measure and cut the straight PVC pipe to fit between the existing pipe and Charlotte pipe PVC hub combo wye fitting.
  6. Broken PVC Pipe Cleanout Replacement: 步骤 6 中的图像 1,3 Broken PVC Pipe Cleanout Replacement: 步骤 6 中的图像 2,3 Broken PVC Pipe Cleanout Replacement: 步骤 6 中的图像 3,3
    • Apply the primer on the outside end of the straight pipe and inside the end of the Charlotte pipe PVC hub combo wye fitting.
  7. Broken PVC Pipe Cleanout Replacement: 步骤 7 中的图像 1,3 Broken PVC Pipe Cleanout Replacement: 步骤 7 中的图像 2,3 Broken PVC Pipe Cleanout Replacement: 步骤 7 中的图像 3,3
    • Apply the PVC cement on the ends of both the straight pipe and Charlotte pipe PVC hub combo wye fitting and press firmly together.
  8. Broken PVC Pipe Cleanout Replacement: 步骤 8 中的图像 1,3 Broken PVC Pipe Cleanout Replacement: 步骤 8 中的图像 2,3 Broken PVC Pipe Cleanout Replacement: 步骤 8 中的图像 3,3
    • Prime and glue the rest of the pieces together one at a time.
  9. Broken PVC Pipe Cleanout Replacement: 步骤 9 中的图像 1,3 Broken PVC Pipe Cleanout Replacement: 步骤 9 中的图像 2,3 Broken PVC Pipe Cleanout Replacement: 步骤 9 中的图像 3,3
    • Twist rubber coupling sleeve over both the existing pipe and the short straight pipe. Secure the circle clamp by tightening the screws with the flat head screwdriver.
结论
Michael Frizzell
于03/25/20注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 3,990
