跳转到主内容
Broil-King BBQ Heat Indicator Replacement Guide
你所需要的
  1. Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: 步骤 1 中的图像 1,3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: 步骤 1 中的图像 2,3 Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: 步骤 1 中的图像 3,3
    • Gather the tools and parts needed for the repair:
    • Crescent Wrench
    • Scraper
    • Replacement Heat Indicator
    • Be sure that the grill is completely cool and disconnect any gas tanks before beginning the repair.
  2. Broil-King BBQ Heat Indicator Replacement Guide: 步骤 2 中的图像 1,2 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 2 中的图像 2,2
    • Open the lid and then remove the nut securing the heat indicator.
    • Use a crescent wrench to loosen the nut.
    • Continue to unthread the nut with your fingers.
    • Place the nut in a secure location for later use.
  3. Broil-King BBQ Heat Indicator Replacement Guide: 步骤 3 中的图像 1,2 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 3 中的图像 2,2
    • Close the lid.
    • Slide the flat edge of the paint scraper under the existing heat indicator plate to pry the plate loose.
    • Lift the plate up, then off of the predrilled holes.
  4. Broil-King BBQ Heat Indicator Replacement Guide: 步骤 4 中的图像 1,3 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 4 中的图像 2,3 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 4 中的图像 3,3
    • Push the heat indicator from the back to remove it from the Broilmate plate.
  5. Broil-King BBQ Heat Indicator Replacement Guide: 步骤 5 中的图像 1,3 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 5 中的图像 2,3 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 5 中的图像 3,3
    • Align the new heat indicator through the front of the plate.
    • Move your thumbs around the plate until the heat indicator is secure.
  6. Broil-King BBQ Heat Indicator Replacement Guide: 步骤 6 中的图像 1,3 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 6 中的图像 2,3 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 6 中的图像 3,3
    • Align the new heat indicator and plate with the factory drilled holes on the face of the BBQ.
    • Hold the plate in place while opening the lid.
  7. Broil-King BBQ Heat Indicator Replacement Guide: 步骤 7 中的图像 1,2 Broil-King BBQ Heat Indicator Replacement Guide: 步骤 7 中的图像 2,2
    • Retrieve the nut used on the previous heat indicator (remember you put it in a secure location).
    • Thread the nut on the new heat indicator.
    • Use a crescent wrench to finish tightening the nut on the new bolt.
  8. Broil-King BBQ Heat Indicator Replacement Guide: 步骤 8 中的图像 1,1
    • Close the lid. You're done!
结论
This simple repair doesn’t take much time, yet is well worth the effort. A working heat indicator provides the necessary information about the temperature to ensure safe food practices, and produce a tasty outcome.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 34
总计 750
