跳转到主内容
Brightsign 4k Heat Sink Replacement
你所需要的
  1. Brightsign 4k Heat Sink Replacement, Outer Shell: 步骤 1 中的图像 1,3 Brightsign 4k Heat Sink Replacement, Outer Shell: 步骤 1 中的图像 2,3 Brightsign 4k Heat Sink Replacement, Outer Shell: 步骤 1 中的图像 3,3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Heat Sink Replacement: 步骤 2 中的图像 1,3 Brightsign 4k Heat Sink Replacement: 步骤 2 中的图像 2,3 Brightsign 4k Heat Sink Replacement: 步骤 2 中的图像 3,3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Heat Sink Replacement: 步骤 3 中的图像 1,3 Brightsign 4k Heat Sink Replacement: 步骤 3 中的图像 2,3 Brightsign 4k Heat Sink Replacement: 步骤 3 中的图像 3,3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Heat Sink Replacement: 步骤 4 中的图像 1,3 Brightsign 4k Heat Sink Replacement: 步骤 4 中的图像 2,3 Brightsign 4k Heat Sink Replacement: 步骤 4 中的图像 3,3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Heat Sink Replacement, Motherboard Removal: 步骤 5 中的图像 1,2 Brightsign 4k Heat Sink Replacement, Motherboard Removal: 步骤 5 中的图像 2,2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Heat Sink Replacement: 步骤 6 中的图像 1,2 Brightsign 4k Heat Sink Replacement: 步骤 6 中的图像 2,2
    • Lift the motherboard out of the casing.
  7. Brightsign 4k Heat Sink Replacement, Heat Sink: 步骤 7 中的图像 1,2 Brightsign 4k Heat Sink Replacement, Heat Sink: 步骤 7 中的图像 2,2
    • Flip the motherboard upside down.
  8. Brightsign 4k Heat Sink Replacement: 步骤 8 中的图像 1,3 Brightsign 4k Heat Sink Replacement: 步骤 8 中的图像 2,3 Brightsign 4k Heat Sink Replacement: 步骤 8 中的图像 3,3
    • Remove the black adhesive that covers the four screws.
    • Remove the four screws.
    • Flip the motherboard over and remove the heat sink by pulling up.
结论
Mattison Collins
于02/15/18注册
85 声望
撰写一个指南
团队
USF Tampa, Team S17-G6, Boczar Spring 2018 USF Tampa, Team S17-G6, Boczar Spring 2018 的会员
USFT-BOCZAR-S18S17G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 224
