跳转到主内容
Briggs and Stratton 675 Series Spark Plug Replacement
你所需要的
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: 步骤 1 中的图像 1,2 Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: 步骤 1 中的图像 2,2
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 步骤 2 中的图像 1,3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 步骤 2 中的图像 2,3 Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: 步骤 2 中的图像 3,3
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
结论
7等其他人完成本指南。
Andrew Saunders
于02/01/15注册
1,056 声望
创作了2篇指南
团队
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015 的会员
CPSU-AMIDO-W15S6G31
4 名成员
创作了19篇指南
14指南评论
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - 回复
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - 回复
pinch the front of black cap and pull off
tracy.mullen - 回复
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - 回复
just remove the plug and take it with you
when buying a new plug
Bill -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 129
总计 51,618
