跳转到主内容
加入维修社区 - 创建账户
Briefcase Strap Holder Replacement
你所需要的
  1. Briefcase Strap Holder Replacement, Strap Holder: 步骤 1 中的图像 1,1
    • Cut the whole old strap holder from the bag.
    • If the strap holder breaks in other parts, cut it all out.
  2. Briefcase Strap Holder Replacement: 步骤 2 中的图像 1,2 Briefcase Strap Holder Replacement: 步骤 2 中的图像 2,2
    • Draw a longer shape of the strap holder with a pencil on another piece of fabric.
    • Both extensions should be the same length, at least 1/4 to 1/2inch long.
  3. Briefcase Strap Holder Replacement: 步骤 3 中的图像 1,1
    • Cut the piece of fabric.
  4. Briefcase Strap Holder Replacement: 步骤 4 中的图像 1,2 Briefcase Strap Holder Replacement: 步骤 4 中的图像 2,2
    • Add glue in the center of the new piece of fabric.
    • Glue the strap holder on in the center and leave the same length on both sides.
    • You can also use a glue gun.
  5. Briefcase Strap Holder Replacement: 步骤 5 中的图像 1,2 Briefcase Strap Holder Replacement: 步骤 5 中的图像 2,2
    • Use a sewing machine to sew the strap holder with the glued piece of fabric in the center.
    • If you have good sewing skills, you can sew on both sides.
  6. Briefcase Strap Holder Replacement: 步骤 6 中的图像 1,2 Briefcase Strap Holder Replacement: 步骤 6 中的图像 2,2
    • Place the metal strap holder between the leather strap holder and fold it.
    • Use the sewing machine to sew the tips of the fabric that was glued on the leather strap holder.
    • If your metal strap holder is openable, sew without the metal strap holder.
  7. Briefcase Strap Holder Replacement: 步骤 7 中的图像 1,2 Briefcase Strap Holder Replacement: 步骤 7 中的图像 2,2
    • Add more glue between the fabric and the leather strap holder to strengthen it and hold it while it dries.
  8. Briefcase Strap Holder Replacement: 步骤 8 中的图像 1,1
    • Trim the area where the strap holder is placed.
  9. Briefcase Strap Holder Replacement: 步骤 9 中的图像 1,3 Briefcase Strap Holder Replacement: 步骤 9 中的图像 2,3 Briefcase Strap Holder Replacement: 步骤 9 中的图像 3,3
    • Add glue with a glue gun to the area where the strap holder is placed.
    • Place the strap holder in the strap holder area of the bag and hold it while it dries.
    • It is recommended to sew the strap holder fabric to the area where it will be placed.
终点
Hao Yi Michelle Lu
于11/05/24注册
169 声望
撰写一个指南
团队
UC Davis, Team 1-8, Vidal-Chiesa Fall 2024 UC Davis, Team 1-8, Vidal-Chiesa Fall 2024 的会员
UCD-VIDAL-CHIESA-F24S1G8
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 39
总计 374
