跳转到主内容
Breville BKC600XL Water Valve Replacement
你所需要的
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: 步骤 1 中的图像 1,3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: 步骤 1 中的图像 2,3 Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: 步骤 1 中的图像 3,3
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: 步骤 2 中的图像 1,1
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: 步骤 3 中的图像 1,3 Breville BKC600XL Water Valve Replacement, Silver Casing: 步骤 3 中的图像 2,3 Breville BKC600XL Water Valve Replacement, Silver Casing: 步骤 3 中的图像 3,3
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: 步骤 4 中的图像 1,1
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
结论
Antonio
于09/26/12注册
120 声望
创作了6篇指南
团队
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G3
4 名成员
创作了6篇指南
2条评论
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 17
总计 5,832
