跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Replacing the spring should it fail to work.
  1. Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver. Reminder for reassembly; This bottom piece is first to be screwed back on. Reminder for reassembly; This bottom piece is first to be screwed back on.
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  4. Remove the grey plastic casing. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver. Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  5. Identify the spring and the hook its attached to.
    • Identify the spring and the hook its attached to.
    • Carefully remove the spring.
结论
Antonio
于2012年09月26日注册
81 信誉积分
创作了6篇指南
团队
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G3
4 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 2
过去的30天: 11
总计 1,425
