简介
Replacing the spring should it fail to work.
你所需要的
Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
Remove the grey plastic casing.
Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
即将完成!
结论
