简介
Replacing the On/Off switch should the wiring become faulty.
你所需要的
Use a Phillips #0 screwdriver to remove the following ten screws:
Four 18mm Phillips screws.
Four 9.75mm Phillips screws.
Two 8mm Phillips screws.
Use a Phillips #0 screwdriver to remove the following six screws:
Six 14.5mm Phillips screws.
Remove the power cord from the groove. (the black cord that leads into the green wire.)
Carefully remove the On/Off Switch from its slot on the outside cover.
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
2等其他人完成本指南。
2条评论
