跳转到主内容
Breville BKC600XL On/Off Switch Replacement
你所需要的
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 步骤 1 中的图像 1,3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 步骤 1 中的图像 2,3 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: 步骤 2 中的图像 1,2 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: 步骤 2 中的图像 2,2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: 步骤 3 中的图像 1,2 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: 步骤 4 中的图像 1,2 Breville BKC600XL On/Off Switch Replacement, Power Cord: 步骤 4 中的图像 2,2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: 步骤 5 中的图像 1,1
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  6. Breville BKC600XL On/Off Switch Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
结论
2等其他人完成本指南。
Antonio
于09/26/12注册
120 声望
创作了6篇指南
团队
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G3
4 名成员
创作了6篇指南
2条评论
Any source for the switch?
Mark Bell - 回复
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 3,535
