跳转到主内容
Breville BKC600XL Heating Tank Replacement
你所需要的
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 步骤 1 中的图像 1,3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 步骤 1 中的图像 2,3 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 步骤 1 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: 步骤 2 中的图像 1,2 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: 步骤 2 中的图像 2,2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: 步骤 3 中的图像 1,2 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: 步骤 4 中的图像 1,2 Breville BKC600XL Heating Tank Replacement, Power Cord: 步骤 4 中的图像 2,2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: 步骤 5 中的图像 1,2 Breville BKC600XL Heating Tank Replacement, Clear Hose: 步骤 5 中的图像 2,2
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: 步骤 6 中的图像 1,1
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
结论
2等其他人完成本指南。
Antonio
于09/26/12注册
120 声望
创作了6篇指南
团队
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 20
总计 4,592
