跳转到主内容
Brentwood TS-292B Power Cable Replacement
你所需要的
  1. Brentwood TS-292B Power Cable Replacement, Power Cable: 步骤 1 中的图像 1,1
    • Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
  2. Brentwood TS-292B Power Cable Replacement: 步骤 2 中的图像 1,1
    • To remove the toasting lever, pull the lever away from the toaster.
  3. Brentwood TS-292B Power Cable Replacement: 步骤 3 中的图像 1,1
    • Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
  4. Brentwood TS-292B Power Cable Replacement: 步骤 4 中的图像 1,1
    • Unscrew the wire bracket with a Phillips #2 screw driver.
  5. Brentwood TS-292B Power Cable Replacement: 步骤 5 中的图像 1,1
    • Pull back on the black tab that is holding the circuit board in place.
    • While pulling the tab back, lift up on the circuit board.
  6. Brentwood TS-292B Power Cable Replacement: 步骤 6 中的图像 1,1
    • Desolder the power wire connections on the circuit board.
    • Desolder in a well ventilated area.
    • The tip of soldering iron is hot handle with caution.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 12
总计 159
