跳转到主内容
Brentwood TS-292B Browning Dial Circuitboard Replacement
你所需要的
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 步骤 1 中的图像 1,3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 步骤 1 中的图像 2,3 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 步骤 1 中的图像 3,3
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: 步骤 2 中的图像 1,2 Brentwood TS-292B Browning Dial Circuitboard Replacement: 步骤 2 中的图像 2,2
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: 步骤 3 中的图像 1,1
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: 步骤 4 中的图像 1,2 Brentwood TS-292B Browning Dial Circuitboard Replacement: 步骤 4 中的图像 2,2
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: 步骤 5 中的图像 1,2 Brentwood TS-292B Browning Dial Circuitboard Replacement: 步骤 5 中的图像 2,2
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 230
